[Se...] Posted October 23 Share Posted October 23 Hi PiWebians, Come across an issue I seemingly cannot fix. When plotting roundness in PiWeb it is “transposed” and there is no option to reverse it, if you use a legacy plot there is an option to transpose, this then makes the plot reflect the CAD evaluation when displaying points, which I can only assume is the true representation. Does anyone know how to transpose a PiWeb plot? Thanks in advance Link to comment https://qualityforum.zeiss.com/topic/27738-roundness-plot-transposed/ Share on other sites More sharing options...
[Se...] Posted October 28 Author Share Posted October 28 Photos added Link to comment https://qualityforum.zeiss.com/topic/27738-roundness-plot-transposed/#findComment-157558 Share on other sites More sharing options...
[Ma...] Posted October 29 Share Posted October 29 In PiWeb designer you can create a template where you can have this graph mirrored. Go to editor - click on "Pages" and select "Plot" page Now in "Structure" expand tree in "Main section -> Roundness template -> Roundness" and click "Properties" Find "Mirrored" and check it. That's the only option. Link to comment https://qualityforum.zeiss.com/topic/27738-roundness-plot-transposed/#findComment-157570 Share on other sites More sharing options...
[Ma...] Posted October 29 Share Posted October 29 Please sign in to view this username. is right, that is the only option within PiWeb: But you cannot choose a mirror axis as you could within the "old" Protocol (i also couldnt figure out about what axis the rotation gets done): In your case i would suggest to turn the CAD View to match the PiWeb Plot as an "easy" solution. In general an entry in the "My Voice" Area within the Zeiss Portal would be a good idea to ask for the same functionality as it was in the "old" protocol. Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/27738-roundness-plot-transposed/#findComment-157578 Share on other sites More sharing options...
[Ze...] Posted October 29 Share Posted October 29 I think the plot orientations are related to the alignment of the feature? You could theoretically either assign a different alignment to the feature and/or recall features into new constructed features and assign alignments to them that would generate the plot orientation you want. Less than elegant, but it should work in a pinch. Link to comment https://qualityforum.zeiss.com/topic/27738-roundness-plot-transposed/#findComment-157596 Share on other sites More sharing options...
