[Se...] Posted October 26 Share Posted October 26 Hi all, Think I'm having a brain loss moment and cannot figure out how to align a particular part (will add photos when I’m in work). Part is 1” square tube bent into a half ring, the half ring is then twisted/tilted 30 degrees, meaning there is no ‘flat’ surface to create a plane on. Can’t help but feel I’m missing something simple? Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/ Share on other sites More sharing options...
[Ma...] Posted October 26 Share Posted October 26 Special button in alignment window - add rotation. Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157412 Share on other sites More sharing options...
[Lu...] Posted October 26 Share Posted October 26 Well you can mesure allways a cylinder and align and create a prependicular plane therorical from the measured cylindr, but you need allwazs a point to create a origin for one of the axis Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157420 Share on other sites More sharing options...
[Se...] Posted October 28 Author Share Posted October 28 Picture added in case my rambling didn’t make sense! This is how to part sits on the CMM. Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157522 Share on other sites More sharing options...
[Du...] Posted October 28 Share Posted October 28 (edited) Did a quick sketch to see how calypso would work with it, looks like calypso thinks it would be a cone. you could use that surface as your X and Y origin and the intersection of that and the outer surface as your Z origin for your base alignment Edited October 28 fixed wording 1 1 Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157524 Share on other sites More sharing options...
[Ma...] Posted October 28 Share Posted October 28 If you can - make lines and their intersections at least 3 times around a part - that should be sufficient. 1 1 Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157534 Share on other sites More sharing options...
[Lu...] Posted October 30 Share Posted October 30 Mesure the ring faces to level up the plane and in the special button rotate 30° coordinate system on Y axis Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157618 Share on other sites More sharing options...
[Be...] Posted October 30 Share Posted October 30 Please sign in to view this quote. This is the approach that I would use. three points define the plane and potentially the center of the part. I might use some side holes to control rotation about the Z axis and similarly the X? direction (the direction that the arc is open. Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157662 Share on other sites More sharing options...
