[Se...] Posted 4 hours ago Share Posted 4 hours ago Hi all, Think I'm having a brain loss moment and cannot figure out how to align a particular part (will add photos when I’m in work). Part is 1” square tube bent into a half ring, the half ring is then twisted/tilted 30 degrees, meaning there is no ‘flat’ surface to create a plane on. Can’t help but feel I’m missing something simple? Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/ Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago Special button in alignment window - add rotation. Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157412 Share on other sites More sharing options...
[Lu...] Posted 35 minutes ago Share Posted 35 minutes ago Well you can mesure allways a cylinder and align and create a prependicular plane therorical from the measured cylindr, but you need allwazs a point to create a origin for one of the axis Link to comment https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/#findComment-157420 Share on other sites More sharing options...
