Tilted plane used for alignment
Hi all,
Think I'm having a brain loss moment and cannot figure out how to align a particular part (will add photos when I’m in work).
Part is 1” square tube bent into a half ring, the half ring is then twisted/tilted 30 degrees, meaning there is no ‘flat’ surface to create a plane on.
Can’t help but feel I’m missing something simple?
https://qualityforum.zeiss.com/topic/27748-tilted-plane-used-for-alignment/
Did a quick sketch to see how calypso would work with it, looks like calypso thinks it would be a cone. you could use that surface as your X and Y origin and the intersection of that and the outer surface as your Z origin for your base alignment
fixed wording
