[Ri...] Posted October 26 Share Posted October 26 I haven't been able to figure this out. I have a bunch of Program Stops for user interaction and I used images to show where the activity should occur. The images will no longer display at run time after a program name change. The path is correct. The name of the file is correct. The file exists in the path. But Calypso says it's not there. For testing. I copy/pasted the feature. I opened the program stop and reselected the image to display. Now it works in the new feature (name is slightly different. Original feature name: Cylinder 1277 10-C3. New test feature name: Cylinder 1277 10-C4. Do I have to manually edit each feature? Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/ Share on other sites More sharing options...
[Lu...] Posted October 26 Share Posted October 26 hi richard i use the images or word files that contain instructions inside the program, so when the program moves the path should remaisn the same.. Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157432 Share on other sites More sharing options...
[DC...] Posted October 26 Share Posted October 26 ~not quite~ the same... Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157436 Share on other sites More sharing options...
[Lu...] Posted October 26 Share Posted October 26 hi richard, you are rigth, i just tested and the link is broken so teh instruction dont show anymore im trying find a way with chat gpt it seems with PCM license is possible to open the instructions even if you move the path. without it seems that maybe can work with .Bat file.. please check this link... https://www.victoryprogramming.com/post/calypso-tip-16-how-to-add-setup-instructions i will test in my side if you find a solution please share Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157438 Share on other sites More sharing options...
[Lu...] Posted October 26 Share Posted October 26 (edited) Hi richard i i just tested and is working now with the .bat file the only thing you need reconfigure each program but after if you move the program the user information button will work or any programable stop with the .bat files you use. please see the file attached Zeiss User instructions.txt Edited October 26 Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157440 Share on other sites More sharing options...
[Ri...] Posted October 26 Author Share Posted October 26 Please sign in to view this quote. Ive stared at this 10 or more times...🫤 Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157444 Share on other sites More sharing options...
[DC...] Posted October 26 Share Posted October 26 Sometimes you need fresh eyes on a problem. 🧐 2 Link to comment https://qualityforum.zeiss.com/topic/27750-programmable-stop-using-user-information-as-an-image/#findComment-157448 Share on other sites More sharing options...
