Programmable Stop using "User Information", as an image.
I haven't been able to figure this out.
I have a bunch of Program Stops for user interaction and I used images to show where the activity should occur.
The images will no longer display at run time after a program name change.
The path is correct.
The name of the file is correct.
The file exists in the path.
But Calypso says it's not there.
For testing.
I copy/pasted the feature.
I opened the program stop and reselected the image to display.
Now it works in the new feature (name is slightly different. Original feature name: Cylinder 1277 10-C3. New test feature name: Cylinder 1277 10-C4.
Do I have to manually edit each feature?
hi richard,
you are rigth, i just tested and the link is broken so teh instruction dont show anymore
im trying find a way with chat gpt it seems with PCM license is possible to open the instructions even if you move the path. without it seems that maybe can work with .Bat file..
please check this link...
https://www.victoryprogramming.com/post/calypso-tip-16-how-to-add-setup-instructions
i will test in my side if you find a solution please share
Hi richard i
i just tested and is working now with the .bat file the only thing you need reconfigure each program but after if you move the program the user information button will work or any programable stop with the .bat files you use.
please see the file attached
Zeiss User instructions.txt
