Impeller help
I have an impeller. Six helical blades tapering to the top. I need to find the diameter of the blades at the bottom and at the top. I created a cross section thru the bottom to start. How do find that diameter?
I have tried maximum coordinate in polar and then made a circle out of those points but it doesn't put it where I thought it would
I am open to any and all advice.
https://qualityforum.zeiss.com/topic/27764-impeller-help/
Multiple ways to skin this cat.  I work with these all the time and can give you some tips.
First off, There's better ways to get that OD than a cmm.  Something like an OptiCline or a custom gage like we have.
But if you have to get on a cmm there's a few things you can try.  Like Richard said, you can make an alignment that is clocked to each blade.  This is possible but kinda sucks too.  Clock the alignment to a symmetry point made from points on either side.
OR
what I recommend is measuring multiple blades with curves.  Then recall those individual curves into another curve.  Then you can use a circle with Max Inscribed or Min Circumscribed to give you a diameter.
Like this: We have a complex shaped curve, and the circle is just fitting around the outside for the OD.
  • Like! 2
https://qualityforum.zeiss.com/topic/27764-impeller-help/#findComment-157548
Thank you both
. The alignments should be obvious but I have never used maximum coordinate for anything I have done. As for recalling feature points into another curve then calling that into circle, I also would not have thought of that. I will give these a shot tonight.
https://qualityforum.zeiss.com/topic/27764-impeller-help/#findComment-157556
