[Ma...] Posted October 29 Share Posted October 29 Hi, I am facing a problem with customer stating small inner thread. I would need to measure all what can be measured. We have: Accura with VAST XT head -> what probes and cal. spheres we need? ATOS 5 MV500 -> only measurement with cutted part to examine thread - i believe we would need much smaller MV ( around 50 or 100 ) Contourgraph -> we have only onsided blade - i am not sure how to connect two contours scanned with two tips ( one - only Z+ - second only Z- ) Any ideas what would we need to properly measure this small thread ( a hole thats above ⌀20 mm )? I would use Accura - buy two small tips ( R < 0.5mm ), DK 8 cal. sphere and make holder to have both tips against each other to be able to measure oposing curves. We would like to have at least something to show - thread caliper is used, but this is not enough ( told by higher ups ) Thanks for suggestions and tips. Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/ Share on other sites More sharing options...
[Pe...] Posted October 29 Share Posted October 29 Something I saw recently and was interested in was an internal thread mic found here: https://willrich.com/product/multi-ball-internal-thread-micrometer/ 2 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157582 Share on other sites More sharing options...
[Wo...] Posted October 29 Share Posted October 29 Or this: https://willrich.com/product/fowler-screw-threads/ I'm not sure you'll be able to measure the thread that small. We do check the pitch diameter on some threads, but you would need a stylus close in size the the thread wire for that pitch. What's the pitch on that thread btw? 1 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157584 Share on other sites More sharing options...
[Ch...] Posted October 29 Share Posted October 29 Some microscope software can create a 3d topology that you can then section like an optical comparator. I'm thinking of the Zeiss AxioZoom and Keyence VHX. We used to have the Zeiss AxioZoom but now use the Keyence VHX. You'll have to cut the part to get the inner threads under the microscope. I just measured flank angle on a thread this morning using our Keyence VHX. 1 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157588 Share on other sites More sharing options...
[Ma...] Posted October 29 Author Share Posted October 29 Thanks for your replies. Please sign in to view this username. i didn't know there is such solution - but i think very outside our possible budget 😞 But definitelly i'll keep it in head for later problems 🙂 Please sign in to view this username. and Please sign in to view this username. very nice tools - i'll try to find something similar in our reach - i think it's better invested money, than buying new sphere, tips and tryharding solution with noone would sign under that measurement 🙂 Also if anyone has another solution i am one ear 🙂 Thanks a lot. Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157594 Share on other sites More sharing options...
[Ch...] Posted October 30 Share Posted October 30 (edited) I would measure the core diameter using the Accura and a 2.5-3mm ball probe. For contours and angles use your contour pen; then multiply the result of the contour recorder by two and add it to the core diameter. Measure the core diameter with a spiral track (pitch 2.5 mm) using the Pferch/Gauss method. https://theoreticalmachinist.com/Threads-MetricMProfile.aspx Edited October 30 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157628 Share on other sites More sharing options...
[Ja...] Posted November 2 Share Posted November 2 (edited) I have had some success using molds of internal threads and then checking them on a vision system or optical comparator. Depending on how small and class of thread you are working with it may be a lower cost option and you may be able to avoid destructive testing on parts. I have passed government first article inspections by basically digitally recreating the three-wire method on our vision system and measuring the thread mold. Here is the mold kit we use but there may be much more cost effective options. Here is kind of a basic how-to on how to get started using molds for threads measurements. Edited November 2 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157712 Share on other sites More sharing options...
[Ma...] Posted November 2 Author Share Posted November 2 Please sign in to view this quote. Sorry, but this is not reliable - we are facing potential problem, where thread caliper is not fitting ( small thread ). So we need to measure thread directly - also part itself is a little problematic how to catch thread axis - part putted on a side to have thread in +Z will have tilt about 1° due draft angles. For measuring thread position it's already used like that ( bigger sphere with self centering into thread ) Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157718 Share on other sites More sharing options...
[Ma...] Posted November 2 Author Share Posted November 2 Please sign in to view this quote. I have read about molds, but i fear about shrinkage - customer stated NOK with thread caliper, our caliper was on edge but ok. But our machining is done by 3rd party, so we need some measurement aand numbers to show - they are stubborn 😞 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157720 Share on other sites More sharing options...
[Ri...] Posted November 2 Share Posted November 2 Please sign in to view this quote. They make mold material with extremely low shrinkage rates. Please sign in to view this quote. 2 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157734 Share on other sites More sharing options...
[Du...] Posted November 2 Share Posted November 2 We use this specific one all the time, very low shrinkage also a good bit cheaper than reprorubber 1 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157740 Share on other sites More sharing options...
[Ch...] Posted November 3 Share Posted November 3 I understand the issue you're facing. Using my method, we were actually able to help a client in the medical sector with an implant; we discovered that their competitor had been using the wrong tool insert—specifically, the internal radius within the thread profile was too small. What does your supplier have to say about this? Can they provide you with the tool so it can be measured? Are they able to offer you any support? Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157744 Share on other sites More sharing options...
[Ma...] Posted November 3 Share Posted November 3 Please sign in to view this username. Hi and thanks. I think this situation is outside of this forum. We let 3rd party to do machining - it was partialy ok on our thread calibers - but customer is reporting back NOK with same method - thread caliber. So now it's between us and 3rd party. QS want's some numbers as a leverage, but they don't care how we get them. I would scrape that away immediately, but that is not on me. So it will be a long boring communication back and forth. So due cost saving i'll do request for 2 L probes ( dia 0,8mm without thread ) and do 2point distance with calculation of probe diameter to obtain mean diameter. Then contour for angles. Pitch can be taken on Accura or contour. 1 Link to comment https://qualityforum.zeiss.com/topic/27776-how-to-fully-measure-inner-thread-like-m22-6h/#findComment-157750 Share on other sites More sharing options...
