[Ka...] Posted October 30 Share Posted October 30 Hi Expert, We need to use plate stylus which must be simulated by Planner ( No joke, it’s a grim reality... ) CALYPSO 7.4.24 Using the Zeiss Stylus-kit 1.7.8817 I can define a plate stylus using generic geometry. At the End I´m not able to define the plate as a sensor. Try to load the ssc file in planner end´s with and error message. How do you define your own plate stylus to be able to simulate this in Planner?? Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/ Share on other sites More sharing options...
[Ri...] Posted October 30 Share Posted October 30 (edited) Your info is blocked in your image, Im guessing its similar to this setup. I use these all the time and show a full Disk in Planner. See image. Attached is an SSC file you can look at. (In 7z zipped format. Combo76R.7z Edited October 30 Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157632 Share on other sites More sharing options...
[Ka...] Posted November 2 Author Share Posted November 2 Hi Richard, Thank you for the example and the hint to use a generic stylus. All I can define is a small tip and align DS / DG / L in this way that the tip is plan to the disk. In this case I can use the stylus only in -Z direction. But I need to use the disk stylus as a real physical stylus, means the outer diameter of Ø14, the plane in -Z as well as +Z. How to define such a stylus? Attached my example .... Regards Karsten Q42421.zip Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157688 Share on other sites More sharing options...
[Ri...] Posted November 2 Share Posted November 2 (edited) All you have left to do is change the radius value. After you change the value, calibrate the disc with a Ring Gage then edit the Radius value to match. For using the upper or lower plane surfaces as contact points, I calibrate my Disk styli with a custom program that uses the Reference Sphere. This allows me to control all three axes. When using the Disk, you will have to manually calculate the difference from center of the disk (It is treated as a sphere) to the surface used for probing, I also use this method in my programs. Most reported values I use a Result Element and calculate the difference. When I use this method, I always use one quadrant of the disk (Let's say 3 O'clock) and only about .02" (inch) of depth from the outer radius of the disk due to the disk is never perfectly normal to the surface being probed. All results are verified in some form of a manual measurement and the Result Element adjusted as needed. Edited November 2 Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157690 Share on other sites More sharing options...
[Ka...] Posted November 2 Author Share Posted November 2 Richard, Thanks for the description how to calibrate a disc stylus. The issue is not the calibration or using the stylus in physic. It’s simply a question of how to use a button like this in the Planner. In the Button Builder, I can create the button using generic geometries. With the generic button, I can define the flat sides of the button. If I change the radius to 7 mm, I can only use the radius and no longer the flat sides, as a partially invisible sphere with a diameter of 14 is defined.... We need a reliable method in Planner to simulate a disc stylus with both contact surfaces. Just like a real disc stylus.. 1 Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157698 Share on other sites More sharing options...
[Ri...] Posted November 2 Share Posted November 2 My Monday brain led me astray of your question. Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157702 Share on other sites More sharing options...
[Lu...] Posted November 2 Share Posted November 2 there is another alternative son the link bellow https://www.victoryprogramming.com/post/calypso-tip-7-naming-conventions-2-stylus-systems Link to comment https://qualityforum.zeiss.com/topic/27786-how-define-an-plate-stylus-in-stylus-kit-software/#findComment-157708 Share on other sites More sharing options...
