[Li...] Posted October 30 Share Posted October 30 I've never understood why sometimes I get different true position results when I select a created alignment vs selecting each feature individually for the datums. Can someone please shed some light on this? I saw something pretty different today and don't know why. 505-1 and 505-2 are the specific "features" chosen, 505-3 and 505-4 created alignments. Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/ Share on other sites More sharing options...
[Ke...] Posted October 31 Share Posted October 31 This usually because the "specific features chosen" whithin the Position characteristic is applying Evaluation Methods (such as Outer Tangential, Min Circumscribed, Max Inscribed) to the selected features; whereas, when creating alignments, you must ensure that the correct settings are applied. 3 Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/#findComment-157684 Share on other sites More sharing options...
[Lu...] Posted November 2 Share Posted November 2 (edited) Please sign in to view this quote. Yes i agree you should verify on tolerance position window what calypso is doing datums should be using in ISO the ISO 5459 method, for planes out tangencial feature and for holes and bores, Max Inscribed, Min Circumscribed, Edited November 2 Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/#findComment-157686 Share on other sites More sharing options...
[Jo...] Posted November 2 Share Posted November 2 This is why the new position characteristic makes you select ASME/ISO/LOOSE. It is automatically ensuring compliance with the selected standard and at ALL OTHER TIMES you must account for evaluation manually Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/#findComment-157704 Share on other sites More sharing options...
