[Li...] Posted Friday at 08:56 PM Share Posted Friday at 08:56 PM I've never understood why sometimes I get different true position results when I select a created alignment vs selecting each feature individually for the datums. Can someone please shed some light on this? I saw something pretty different today and don't know why. 505-1 and 505-2 are the specific "features" chosen, 505-3 and 505-4 created alignments. Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/ Share on other sites More sharing options...
[Ke...] Posted Saturday at 01:15 PM Share Posted Saturday at 01:15 PM This usually because the "specific features chosen" whithin the Position characteristic is applying Evaluation Methods (such as Outer Tangential, Min Circumscribed, Max Inscribed) to the selected features; whereas, when creating alignments, you must ensure that the correct settings are applied. 2 Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/#findComment-157684 Share on other sites More sharing options...
[Lu...] Posted 3 hours ago Share Posted 3 hours ago (edited) Please sign in to view this quote. Yes i agree you should verify on tolerance position window what calypso is doing datums should be using in ISO the ISO 5459 method, for planes out tangencial feature and for holes and bores, Max Inscribed, Min Circumscribed, Edited 3 hours ago Link to comment https://qualityforum.zeiss.com/topic/27792-alignment-vs-individual-features/#findComment-157686 Share on other sites More sharing options...
