[na...] Posted November 2 Share Posted November 2 Hi, we are discussing upgrade options and we want to go from old Atos III triple scan [1] to Atos 5 [2] or Atos 5 Airfoil [3]. Our tilt, swivel, lift unit [1] is still working well, but so far we've got short answer from supplier, that it isn't compatible with Atos 5. Can someone comment on this? [1] - https://youtu.be/eKYCgn1L6yY?t=29 [2] - https://www.zeiss.com/metrology/en/systems/optical-3d/3d-scanning/atos/atos-5.html [3] - https://www.zeiss.com/metrology/en/systems/optical-3d/3d-scanning/atos/atos-5-for-airfoil.html Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/ Share on other sites More sharing options...
[Jo...] Posted November 2 Share Posted November 2 Hi, looks like the triple scan has a shorter working distance. Do you have space left to bring the sensor further up on that thing? Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157706 Share on other sites More sharing options...
[Ma...] Posted November 2 Share Posted November 2 ATOS 5 is about 880mm acording to Gemini ATOS 5 Airfoil is about 530mm ATOS 5X i also about 880mm So you may be out of focus on this. Airfoil has ability to better scan sharp turbine blades - i would suggest to try contacting ZEISS or reseller and ask for presentation or visit a company to show what types of part it is capable of measuring. Also note to calculate correct measurement volume - it can be bought later, but switching between them means new calibration and more time, than using correct volume. There is also version of ScanBox, which can be automatized with better control of angle scan of certain area. Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157724 Share on other sites More sharing options...
[na...] Posted November 3 Author Share Posted November 3 Please sign in to view this quote. We could modify holder/plate to get it higher. Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157768 Share on other sites More sharing options...
[na...] Posted November 3 Author Share Posted November 3 (edited) We've also got more detailed answer, current camera configuration on our Atos triple scan is SO (Small Objects), that means we have measuring distance 490 mm, which is close enough to Atos 5 Airfoil which has 530 mm. That should go with the current swivel unit. For Atos 5, as you said measuring distance is 880 mm, which should be fine with swivel unit, if modified to get a scanner higher. We will also demand a demo scan on our part, to be sure to what depth each of 5's can scan. Thank you both. Edited November 3 Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157770 Share on other sites More sharing options...
[Ma...] Posted November 3 Share Posted November 3 Please sign in to view this username. I highly recommend buying version with 12M camera instead of 8M ( that goes to ATOS 5 ) 1 Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157792 Share on other sites More sharing options...
