[na...] Posted 5 hours ago Share Posted 5 hours ago Hi, we are discussing upgrade options and we want to go from old Atos III triple scan [1] to Atos 5 [2] or Atos 5 Airfoil [3]. Our tilt, swivel, lift unit [1] is still working well, but so far we've got short answer from supplier, that it isn't compatible with Atos 5. Can someone comment on this? [1] - https://youtu.be/eKYCgn1L6yY?t=29 [2] - https://www.zeiss.com/metrology/en/systems/optical-3d/3d-scanning/atos/atos-5.html [3] - https://www.zeiss.com/metrology/en/systems/optical-3d/3d-scanning/atos/atos-5-for-airfoil.html Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/ Share on other sites More sharing options...
[Jo...] Posted 3 hours ago Share Posted 3 hours ago Hi, looks like the triple scan has a shorter working distance. Do you have space left to bring the sensor further up on that thing? Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157706 Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago ATOS 5 is about 880mm acording to Gemini ATOS 5 Airfoil is about 530mm ATOS 5X i also about 880mm So you may be out of focus on this. Airfoil has ability to better scan sharp turbine blades - i would suggest to try contacting ZEISS or reseller and ask for presentation or visit a company to show what types of part it is capable of measuring. Also note to calculate correct measurement volume - it can be bought later, but switching between them means new calibration and more time, than using correct volume. There is also version of ScanBox, which can be automatized with better control of angle scan of certain area. Link to comment https://qualityforum.zeiss.com/topic/27794-atos-5-airfoil-tilt-swivel-lift-unit-compatibility/#findComment-157724 Share on other sites More sharing options...
