[Ra...] Posted November 2 Share Posted November 2 I'm coming across an odd bug, not sure if others have encountered it. I have a model assembly. In the hierarchy, I can see all the individual models, and I have the ability to hide or reveal any component I want. However, when I use the CAD-create feature tool, Calypso merges everything into one model. Is there a workaround? Calypso 2025 version 8.0.08 Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/ Share on other sites More sharing options...
[Jo...] Posted November 2 Share Posted November 2 Calypso will merge your entire model into one model the second you try to capture geometry from it. The only sane way is to assume it will be merged. (I have been told you can exempt things from merging by setting the Workpiece/Workarea flag but I cannot seem to figure it out..... ) Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/#findComment-157728 Share on other sites More sharing options...
[Ra...] Posted November 2 Author Share Posted November 2 That is disappointing and sad. My workaround currently is deleting and reloading the CAD model. Super-efficient. Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/#findComment-157736 Share on other sites More sharing options...
[Pe...] Posted November 2 Share Posted November 2 Right click here on them to change them into not workpiece (blue is workpiece). Should prevent merging. 2 Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/#findComment-157738 Share on other sites More sharing options...
[Lu...] Posted November 3 Share Posted November 3 Please sign in to view this quote. Yes only 1 workpiece should be activated if you have several models that are with the workpiece when you extrat elements the models will be merged 1 Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/#findComment-157742 Share on other sites More sharing options...
[Ra...] Posted Tuesday at 04:11 PM Author Share Posted Tuesday at 04:11 PM I can confirm this works. Thanks! Link to comment https://qualityforum.zeiss.com/topic/27796-cad-model-assembly/#findComment-158408 Share on other sites More sharing options...
