Change Segment in 3-D scan
I have a program that has a 3-D scan of the perimeter of the part that has an update to its configuration. How do I change the segment that is changed in the 3-D Curve feature?
The attached screenshot is showing the nominal points of the old version and the cad model of the updated.
The program was written by a colleague in Germany who is not available for assistance.
Thank you!
https://qualityforum.zeiss.com/topic/27798-change-segment-in-3-d-scan/
Here is what i do for editing part of a curve:
  1. make new curve with correct model
  2. remove all points except for needed area
  3. open old curve and remove points from needed area
  4. import new points from curve into old curve.
  5. cut and paste new points into correct position.
I am not sure if you can open new curve and copy points and then past into another curve.
For removing and point modifying you click "Arrow" button under clearance group "CP +Z"
Then you have to modify segment data ( i recommend showing all points with numbers ).
Also note - if you have masked points, then you have to disable it before point modification.
  • Like! 1
Another option:
1. Delete points not needed in old curve
2. Create new curve in the new area needed
3. Open old curve - click dropdown Nominal Geometry Manipulations - Read nominal values
4. Click Append nominal points
5. Click arrow at top right "select curve to append"
6. Click the new curve and Ok, then Ok again.
7. It will then ask if you want to enter a suitable measurement strategy. I usually click no because I will manually edit it myself.
