[Ma...] Posted November 3 Share Posted November 3 Good morning, I have to apply a -0.065 offset on a STL, exept some parts of it. Is it possible? Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/ Share on other sites More sharing options...
[Ma...] Posted November 3 Share Posted November 3 (edited) Operations -> CAD -> add offset Operations -> Mesh -> Special -> add offset I am not sure if that works for selected area, but you can remove selected area. Then only modifications to fill gap. Edited November 3 Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157764 Share on other sites More sharing options...
[Ma...] Posted November 3 Author Share Posted November 3 Thank you, but I don't find under Operation --> Mesh --> Special. I use Zeiss Inspect 2026. 1 Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157772 Share on other sites More sharing options...
[No...] Posted November 3 Share Posted November 3 Your screenshot shows the correct menu item. 1 Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157780 Share on other sites More sharing options...
[Ma...] Posted November 4 Share Posted November 4 Please sign in to view this quote. Hi , that´s right , i using the same option. Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157830 Share on other sites More sharing options...
[Ma...] Posted November 4 Author Share Posted November 4 With offset is not possible to apply it only on some parts of an stl. This was my question. Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157840 Share on other sites More sharing options...
[Ma...] Posted November 4 Share Posted November 4 Then i would select area on mesh and press CTRL+DELETE to remove selected area - make a copy to clipboard and you can offset only one of meshes - then combine them. I am not certain if you can select area on both meshes, but remove one selection on 1st and inverted selection on 2nd mesh Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157842 Share on other sites More sharing options...
[No...] Posted November 4 Share Posted November 4 It would help a bit if we knew what the mesh looks like and what area shall be offset and which one not. Cutting and recombining seems like a possible solution, but I wonder what will happen along the parting line. -0.065 is not a big offset, but despite that the meshes will not fit together properly at the parting line. Will that be a problem? Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157846 Share on other sites More sharing options...
[Ma...] Posted November 5 Author Share Posted November 5 No, it's not a problem. I done it like you say: cutting the part I didn't want to apply the offset then recombining it. But my question was if there was some way to applying the offset only on a selected part of an STL. Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157912 Share on other sites More sharing options...
[Ma...] Posted November 5 Share Posted November 5 It would take a lot of time, but perhaps it would be possible with python script. I got only to a point where it was generating measured points from selected section. I am not sure if you can modify mesh points directly. Link to comment https://qualityforum.zeiss.com/topic/27804-applying-offset-on-stl/#findComment-157920 Share on other sites More sharing options...
