[Jo...] Posted Wednesday at 12:22 PM Share Posted Wednesday at 12:22 PM I have been asked if it was possible to scan a curve, from a plane into a radius (the plane intersects the radius) then evaluate the profile of the radius from the intersect point. The idea is that the intersect point can float with the orientation of the radius. I have had very, very little success with recalling curves and this is the only way I can think of doing it. Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/ Share on other sites More sharing options...
[Ma...] Posted Wednesday at 01:03 PM Share Posted Wednesday at 01:03 PM If i faced a similar case ( obtain a point where is transition from a line into a radius ), the i did bestfitting a curve: rotation in Y axis and translation in X and Z axis - this can vary in your case, but in a same way - 2 axis for translation and 3rd axis as rotation ( remaining one ). Then i made a theoretical point in place where this point should be in nominal and used feature's alignment from this bestfit. Then you can measure this point ( it will move with bestfit ) or you can recall this point into new alignment ( or base alignment ) and report it's origin. Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/#findComment-157857 Share on other sites More sharing options...
[Jo...] Posted Wednesday at 03:08 PM Author Share Posted Wednesday at 03:08 PM trying to evaluate the curve from the point back into the radius not the actual point. I know where the point is by intersecting but they want the evaluation up to this point every time... Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/#findComment-157876 Share on other sites More sharing options...
[Ma...] Posted Wednesday at 04:39 PM Share Posted Wednesday at 04:39 PM I have problems with understanding your problem. You can also recall measured points of a curve into another with using box selection. To keep correct origin where to start or stop you have to have one curve with features alignment where origin is your intersection point. Then recall measured points from this curve and use box - select features alignment for numbers and this box will change position according to this intersection point. Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/#findComment-157878 Share on other sites More sharing options...
[Ri...] Posted Wednesday at 04:47 PM Share Posted Wednesday at 04:47 PM If I'm understanding correctly, you are wanting to scan the curve, and then based on where the intersection point is calculated you want to limit the results from the start of the curve to the intersection point. I do not know of an easy way to do this without PCM, and even with PCM you might have to get creative on determining how the actual intersection point correlates to the corresponding nominal point of the curve. But once you have that "Point Number" you can place formulas on the Recall Feature Points, New Point Range - Point Range from 1 to "insert formula here". The tricky part is going to be then dynamically adjusting Limit evaluation because if you do not skip the calculation of unmeasured points, you will get incorrect results. Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/#findComment-157880 Share on other sites More sharing options...
[Jo...] Posted Thursday at 02:36 PM Author Share Posted Thursday at 02:36 PM yeah... I am trying to talk them out of this. It makes no sense to do it this way. I have had very and I do mean very little success with recalling curves. Was told 2025 fixed a bunch of the issues, but does help me if management does not get the software. Link to comment https://qualityforum.zeiss.com/topic/27812-calypso-2020-curve-help/#findComment-157930 Share on other sites More sharing options...
