[Fi...] Posted November 5 Share Posted November 5 I`ve created 2 3d Curves. Both of them have pretty nice results. Then I`ve created new 3D Curve which is created from these two and I got result which is far from what is suppose to be. - Connected - Separate I`ve tried Recall Points, Connection and it doesn`t work. While I`m trying to check GD&T Line of profile Calypso is not giving me any result from connected Curve, while value for both (separated) is less than 0.02mm. Any hint why is that? Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/ Share on other sites More sharing options...
[Ma...] Posted November 5 Share Posted November 5 How did you created this connected curve? If you recalled measured points with recalculation with actual measured points, then nominals are rewritten according to actual data. Also look if you don't have bad curve spline. Nominal points may have wrong numbering ( last point from 1st curve is not next to 1 point from 2nd curve ) Or send pictures or detail about those curve and their settings. Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/#findComment-157916 Share on other sites More sharing options...
[Fi...] Posted November 5 Author Share Posted November 5 Curve is created from "Recall Points" with recalculation. At first I had wrong numbering, but I created these curves once again from scratches and by default now the have sequential numbers. Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/#findComment-157918 Share on other sites More sharing options...
[Ma...] Posted November 5 Share Posted November 5 You should make a blank curve, then go to point manipulation and add nominals from existing curves. Then swap points, invert direction and other things if needed. If you want to recalculate, then both curves has to be with removed actuals ( it will recalculate with nominals ). 1 1 Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/#findComment-157922 Share on other sites More sharing options...
[Ri...] Posted November 9 Share Posted November 9 I'd probably also suggest to use Curve results points as well. Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/#findComment-158112 Share on other sites More sharing options...
[Jo...] Posted November 11 Share Posted November 11 Have you tried a little filtering? Link to comment https://qualityforum.zeiss.com/topic/27820-connected-curve-gives-very-bad-result-while-separate-are-good/#findComment-158164 Share on other sites More sharing options...
