[He...] Posted November 7 Share Posted November 7 Hello gentlemen, I'm having an issue with my CMM report overlap (Part name) and I was wondering if there are anyone could guide me to edit them. Thank you so much for your help. Henry-T Link to comment https://qualityforum.zeiss.com/topic/27842-report-header-editor/ Share on other sites More sharing options...
[Ma...] Posted November 7 Share Posted November 7 I think if you can access editor, then you just click on that text, right mouse click a select length of text. It will hide rest. But i can not tell for sure - it's a few years since i did that. Editor is in the Prepare menu down hidden in another menu - header editor. Up on opening select same name ( i think vphead ) in correct template folder. I can answer correctly after 36hours from now. 1 Link to comment https://qualityforum.zeiss.com/topic/27842-report-header-editor/#findComment-158042 Share on other sites More sharing options...
[He...] Posted November 7 Author Share Posted November 7 Hi Martin, This what I found but it seems not the right one. Thanks Link to comment https://qualityforum.zeiss.com/topic/27842-report-header-editor/#findComment-158044 Share on other sites More sharing options...
[He...] Posted November 7 Author Share Posted November 7 Please sign in to view this quote. Hi Martin, I'm all set. I was able to figure out how to edit the header/Part name. Thanks for your support. 1 Link to comment https://qualityforum.zeiss.com/topic/27842-report-header-editor/#findComment-158050 Share on other sites More sharing options...
