[Jo...] Posted November 7 Share Posted November 7 I have a hexagon and need to find the inscribed diameter. I've already created intersection points at each corner. Which Construct Circle option should I use to create a circle using the six intersection points of the hexagon? Link to comment https://qualityforum.zeiss.com/topic/27844-inscribed-circle-hexagon/ Share on other sites More sharing options...
[Ma...] Posted November 8 Share Posted November 8 Why not to use section for circle or 6 planes to have cylinder? Then fitting method and use Chebyshev inside/outside or other methods there? If you insist from those six points, then make auto circle or fitting circle, then select all 6 points in tree and right click "Select all points of element" - then you have to select same method as i described at the beggining Link to comment https://qualityforum.zeiss.com/topic/27844-inscribed-circle-hexagon/#findComment-158056 Share on other sites More sharing options...
