Make PiWeb show report of entire last run, even when you view/edit a characteristic.
Can they make PiWeb show the entire report when re-opened instead of just the characteristic(s) you looked at.
I collect data after each CMM run; many times, I have to review data from the PiWeb report (Anything OOT).
doG forbid, I view or edit a characteristic and PiWeb magically closes, or perhaps I accidently closed PiWeb, or saved my program which forces PiWeb to close.
When you try to re-open the report, you get the last characteristic(s) viewed/edited instead of the entire report.
Forcing a user to cycle through the program to generate a new report generates new files and changes the part counter (Which I use as a part counter and or Serial number identification). The current activity forces me to go to the storage locations, remove all the older files that were previously generated and keep the new ones, so I do not get duplicate information.
This is really a pain in the back. Some of my programs are quite large, run times can be up to 4 hours and thousands of characteristics in a single report. Depending on conditions (Using graphics from CAD Evaluation) regeneration of reports can take half an hour or more.
Instead of having a single selection to view the PiWeb report add a second selection.
1. View the last generated report in its entirety.
     1a. Show the report last generated regardless of any changes.
2. View the last characteristic(s) viewed or edited.
This would greatly aid in file management.
Edited
