[To...] Posted 23 minutes ago Share Posted 23 minutes ago Hi all, I’ve set up pallets before and have never run into this issue. I’m using a large fixture with 50 ×\times× 48 slots, for a total of 2,400 parts. When I set up the pallet to measure 96 parts (32 ×\times× 3), the CMM measures them in order, from part 1 through part 96. However, when I increase the number of parts on the same fixture—for example, to 32 ×\times× 6 for 192 parts—the CMM doesn’t follow the expected order. It might measure parts 1, 2, 3, and 4, then jump to 7, 6, and 5, and continue with 8, 9, and so on. In other cases, it measures parts 1 through 32, then goes to part 64 and works backward through 63, 62, and so on. I use the Select All feature rather than selecting the parts manually. My measurement plan is set to measure parts 1 through 192, with a step of 1. It’s important that the parts are measured in order because they’re cavity-driven, and I need to compare parts across different lots. Has anyone experienced a similar issue? Is there a setting I might be missing? Thank you Link to comment https://qualityforum.zeiss.com/topic/27886-pallet-in-autorun-skipping-parts/ Share on other sites More sharing options...
