[Ri...] Posted 6 hours ago Share Posted 6 hours ago I have not ran across this before. I have a section (Circular, sort of) and when I select the curve inside FreeForm it starts it somewhere. I want it to start in a specific point and then scan my profile. Can this be controlled? Link to comment https://qualityforum.zeiss.com/topic/27936-how-to-set-where-the-scan-starts-in-freeform-curves/ Share on other sites More sharing options...
[Ri...] Posted 6 hours ago Author Share Posted 6 hours ago I think I may have figured it out. use Curvature Dependent and set a start angle. Link to comment https://qualityforum.zeiss.com/topic/27936-how-to-set-where-the-scan-starts-in-freeform-curves/#findComment-158662 Share on other sites More sharing options...
[Ma...] Posted 5 hours ago Share Posted 5 hours ago I am using curves for help. First i make a curve in correct point order ( i rather use 3d curve ), then go to same window where you make sections on CAD - on 2nd tab there is an advanced creation of element. You can switch to free form and for selection use that curve's spline - it will make points on CAD model following selected curve. For curve selection i go first to hierarchy and select that spline, then switching for element creation. Link to comment https://qualityforum.zeiss.com/topic/27936-how-to-set-where-the-scan-starts-in-freeform-curves/#findComment-158664 Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Author Share Posted 5 hours ago (edited) Please sign in to view this quote. Unfortunately, I don't have a Curve license, just FreeForm, so I am forced to work in this manner. Edit: I do have curve...LOL You create sections in the model and use those as curves. This creates proper geometry and vectors (When the CAD model is good). Edited 5 hours ago 1 Link to comment https://qualityforum.zeiss.com/topic/27936-how-to-set-where-the-scan-starts-in-freeform-curves/#findComment-158666 Share on other sites More sharing options...
