Measuring the contact point on a marble slab
Hello colleagues,
I have a sheet metal part with a rounded base. The drawing specifies a clearance of 13±0.1. The component is clamped in a three-jaw chuck and measured on a DuraMax.
The customer measures the required clearance by placing the rounded base on a marble slab and using a height probe to measure the distance to the edge of the component.
How can I replicate this measurement procedure on the CMM?
My attempt to capture the arc at three different points using a circular segment and then output the maximum point already produces different results – which aren’t always the same – even during the simulation for Z.
We don’t have ‘curve/free-form’ or PCM on the DuraMax.
Any ideas??
