[Ka...] Posted 9 hours ago Share Posted 9 hours ago Hello colleagues, I have a sheet metal part with a rounded base. The drawing specifies a clearance of 13±0.1. The component is clamped in a three-jaw chuck and measured on a DuraMax. The customer measures the required clearance by placing the rounded base on a marble slab and using a height probe to measure the distance to the edge of the component. How can I replicate this measurement procedure on the CMM? My attempt to capture the arc at three different points using a circular segment and then output the maximum point already produces different results – which aren’t always the same – even during the simulation for Z. We don’t have ‘curve/free-form’ or PCM on the DuraMax. Any ideas??  Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/ Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago Any chance to measure it as a plane? Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/#findComment-158700 Share on other sites More sharing options...
