[Ka...] Posted 15 hours ago Share Posted 15 hours ago Hello colleagues, I have a sheet metal part with a rounded base. The drawing specifies a clearance of 13±0.1. The component is clamped in a three-jaw chuck and measured on a DuraMax. The customer measures the required clearance by placing the rounded base on a marble slab and using a height probe to measure the distance to the edge of the component. How can I replicate this measurement procedure on the CMM? My attempt to capture the arc at three different points using a circular segment and then output the maximum point already produces different results – which aren’t always the same – even during the simulation for Z. We don’t have ‘curve/free-form’ or PCM on the DuraMax. Any ideas?? Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/ Share on other sites More sharing options...
[Ma...] Posted 8 hours ago Share Posted 8 hours ago Any chance to measure it as a plane? Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/#findComment-158700 Share on other sites More sharing options...
[Ri...] Posted 4 hours ago Share Posted 4 hours ago What happens when you create a line across the equator at equal distances left and right. The line should follow the contour with points at minimum and maximum then minimum again. Then from that line recall the maximum value. Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/#findComment-158720 Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Share Posted 3 hours ago Without Curve, I wouldn't really attempt this any other way short of what your customer is doing. Link to comment https://qualityforum.zeiss.com/topic/27938-measuring-the-contact-point-on-a-marble-slab/#findComment-158734 Share on other sites More sharing options...
