[De...] Posted May 31, 2023 Share Posted May 31, 2023 Hi, Is there anyway to .get('Related_elements')? ie. lets say I have a Local Coordinate System with a few dependent elements. Is there a way to access those related elements in the script editor? I've searched through all the keywords and wasnt able to come up with much. Some Pictures Below to help clarify: Link to comment Share on other sites More sharing options...
[Ja...] Posted June 1, 2023 Share Posted June 1, 2023 Hi, you can get a list of the currently shown content with something like this: for x in gom.ElementSelection({'category': ['key', 'related']}): print (x.name) Maybe this helps? Regards, Jan Link to comment Share on other sites More sharing options...
[De...] Posted June 2, 2023 Author Share Posted June 2, 2023 That's exactly what I'm looking for !! & seems to work perfect if I have the element selected in the explorer. but in a normal script/program I'm not going to have that element 'selected'. can I pass a specific element into that gom.ElementSelection function? eg. I'm trying to find all nominal sections related to coordinate system 'LCS' I tried to print( gom.ElementSelection.__doc__ ) but it returned None =( Link to comment Share on other sites More sharing options...
[Ja...] Posted June 5, 2023 Share Posted June 5, 2023 Unfortunately, that is currently not possible. The wish to do that is recorded in our internal ticket system, but I cannot tell you if and when it will be implemented. However, you can use this command to explicitly select an element via scripting: gom.script.explorer.apply_selection(selection=[gom.app.project.inspection['LCS']]) Regards, Jan Link to comment Share on other sites More sharing options...
[De...] Posted June 5, 2023 Author Share Posted June 5, 2023 That'll work! Thank you So much for the help!! Link to comment Share on other sites More sharing options...
