GD&T Outputs via Script
Hello,
I'm trying to build a script that creates a list of features in a project and outputs a variety of information based on the features. This includes stuff like X, Y, Z, I, J, K, Comments & Tolerances etc. The problem I am having is outputting position which is applied to the features via GD&T.
This is an example of how my script currently captures the X,Y & Z coordinates by using the following code:
ele_name = element.get('nominal_element.name')
and X, Y, Z etc using variations of the following.
x_cord = format(element.center_coordinate.x, '.3f')
I need to get the equivalent keywords for the tolerance datum system, tolerance zone type, material requirement, tolerance limit so that I can build a "custom" output comment for the features.
I've tried recording and inputting keywords using the script features however I can't figure out how to adapt the below to work.
I need to get the above element values to work within the list.
Any help, information or guidance would be greatly appreciated.
Cheers
Kris
I managed to fix the issue.
I replaced the gom.app.project.inspection['Circle_1_Example.Position']
section with the term "element.get" similar to the X,Y,Z.
The problem was finding the link to the feature so I had to add another list for any feature that had a GD&T position applied to it and then append the output CSV file to include this information.
