[Ti...] Posted July 2, 2023 Share Posted July 2, 2023 Attached below is a perfect example. You the torx drive pattern was a surface profile and Datum A was the top head face and Datum B was the outside diameter of the threads the clocking/rotation of the part is unconstrained. Is GOM best fitting this or would you need to build features to clock the torx drive profile? It believe in this instance GOM is somehow best fitting the profile in the background as I can't build a clocking tertiary datum to get the measured value any lower. Thanks. Link to comment Share on other sites More sharing options...
[Je...] Posted July 4, 2023 Share Posted July 4, 2023 Hello Mr. Jones, Using A=Plane and B=Cylinder leaves an open rotation. When checking an element with surface profile_AB the rotation will be locked via best fit. (Surface profile with no datum with be a complete best fit (6dof)) Best regards, Jens Braun Link to comment Share on other sites More sharing options...
[Ti...] Posted July 5, 2023 Author Share Posted July 5, 2023 Thanks for the reply. That is a good feature to have working in the background. Thank you. Link to comment Share on other sites More sharing options...
