Hello everyone,
I need to start blade inspect 2022 and  run the user-defined gom script using batch file. I can easily run the script in 2021 using the batch file that I shared below. I guess due to the virtual environment change in the structure, I could not be able to run the same script with 2022 software(I created a virtual env which has the same name as script).
Could you please assist me on how to modify the code below?
start /b "" "C:\Program Files\GOM\2022\bin\gom_inspect.exe" -license gom-inspection-pro,blade,gom-advanced-blade-inpection -eval "gom.script.userscript.example()"
Thanks,
Canset
https://qualityforum.zeiss.com/topic/3079-running-script-from-within-a-batch-file/
