[Di...] Posted July 15, 2021 Share Posted July 15, 2021 Hello all, In my daily routine I need to create programs with Scripts to scan various parts and measure them. I usually export them to a folder and then send them all to an Inspect program (Stages mode) to measure all the parts and get a report. Is it possible to create a program that scans and then exports the MESH to the Inspect program to perform the measurement while placing another part to be scanned and repeat the process? Adding each Scanned part to a new stage?? Thank you Link to comment Share on other sites More sharing options...
[Na...] Posted July 15, 2021 Share Posted July 15, 2021 Hello Diogo, there is an option in the Kiosk setup script for this. Script Choice -> Kiosk Interface -> Setup -> Setup. Do you measure manually or with a scanbox? Regards, Nanno Link to comment Share on other sites More sharing options...
[Di...] Posted July 27, 2021 Author Share Posted July 27, 2021 Manually Link to comment Share on other sites More sharing options...
[Di...] Posted July 27, 2021 Author Share Posted July 27, 2021 Please sign in to view this quote. Manually Link to comment Share on other sites More sharing options...
[Na...] Posted August 9, 2021 Share Posted August 9, 2021 Hi Diogo, there is an example on the bottom of this FAQ page: https://connect.gom.com/display/GKB/Selecting+and+filtering+files+in+Python+scripts You could alter this code or record you own to import meshes as stages. Regards, Nanno Link to comment Share on other sites More sharing options...
