Switch graphic card used by Zeiss Qulity Suite softwares
Hello,
My question is very basic and simple but I couldn't figure out how to do it.
I have a laptop with an RTX 4070. It also has a graphic card integrated to my Intel CPU.
When reading my system the Zeiss Qulity Suite recognizes the integrated GPU as my graphic card.I assume it will then only use the resource of this graphic card to funtion. I would like to change that, and let the software work on my RTX 4070. I have no idea how to do it.
I someone could help me on this that would be welcomed.
Thank you in advance!
Hi Pascal,
You should check in BIOS settings for this option. If you have a workstation device, it should give the option in BIOS to disable the onboard GPU Adapter and only use the nVidia GPU Adapter. For example, all Dell Mobile Workstations we verify and deliver, have the option Disable Hybrid Graphics or Switchable Graphics.
Hope that helps.
Andreas Rousos
Technical Leader
System Integration Engineer
Hello
Thank you for the answer! I don't have a workstation but I still will see if I can check in BIOS to solve the issue.
I'll go back to this topic if it doesn't work.
