Transform by common reference points failed. KIOSK mode error
Hi there.
I'm trying to check 4 parts on 2 sides in multiple parts inspection mode. (I have a 3-axis movement, GOM inspect Pro, Atos Q 12m with lenses 100)
Over Workflow Assistant I built a program with Best Fit Transformation for 4 parts by both sides (not by References Points!) and checked it in Digitize mode my Scan 1 and Scan 2. I got a good results without error.
But in KIOSK mode it gives an error (see attachment). Following the recommendation I looked into the script.
From the first attachment 'transform_measurement_series 2' it become clear to me that 'transformation_method='common_reference_points' those are the common points that Best Fit Transformation will use.
From the second attachment 'transform_measurement_series 3' it become that transforms all digitize measurements into the the first the reference points from the base-plate ... ?!
How can I understand the script and find the cause of my KIOSK error?
Thank in advance
This is currently not supported by Kiosk.
Kiosk always uses "by References Points" transformation to perform top/bottom measurement transformation.
I will register using "Best Fit Transformation" for top/bottom measurement transformation as a software request.
Your case ("Over Workflow Assistant I built a program ... for 4 parts") is covered by the first attached script excerpt (From the first attachment 'transform_measurement_series 2'...). You can patch (overwrite) this method in CustomPatches to use a different transformation method. Just exchanging the command parameter "transformation_method" should be sufficient.
The other script excerpt (From the second attachment 'transform_measurement_series 3'...) is for the single part case only.
