[Ko...] Posted September 27, 2023 Share Posted September 27, 2023 Hello, GOM community! I'm a new user and wanted to find out if it is possible to do the following Import a CAD body, which will be the basis for the comparison Import a mesh of the 3D printed part to compare against the CAD body Import a 2nd mesh of another 3D printed part to also compare against the CAD body Import a 3rd mesh of another part to compare When I import the additional meshes, I'm finding that I cannot perform an accurate local best fit on each imported mesh; the software seems to only allow for a local best fit on one mesh at a time. My ultimate goal is to simultaneously compare the accuracy of the outputs from different 3D printers against the original CAD in one GOM project. Is this possible? Thank you in advance for your thoughts and consideration! Kojo 1 Link to comment Share on other sites More sharing options...
[Be...] Posted September 27, 2023 Share Posted September 27, 2023 Hi, this is possible with the professional version of our software. You can create a trend project and compare each mesh against the CAD and you can even create a small statistic if you choose 'Deviation on CAD'. You can also visualize the differences between the actual meshes against each other. Regards, Bernd Link to comment Share on other sites More sharing options...
[Ko...] Posted September 28, 2023 Author Share Posted September 28, 2023 I see, thanks for your response Bernd! Best regards, Kojo Link to comment Share on other sites More sharing options...
