[os...] Posted November 20, 2023 Share Posted November 20, 2023 I have a RPS alignment and a Local Best Fit alignment with subsequent measurements on each. Obviously when I swap from one to the other, the values are also swapping. I want to create two different Coord Systems replicating the alignments to have the values always fixed even if I change the alignment ... how can I do that ?? thanks in advance. Link to comment Share on other sites More sharing options...
[Na...] Posted November 21, 2023 Share Posted November 21, 2023 Hello Oscar, the workflow is described in this article: ZEISS Quality Tech Guide Or you could document the values on separate report pages. Nanno Link to comment Share on other sites More sharing options...
