Requirements for the optical marker. GOM Correlate 2D
Hello all,
First of all I am glad that this forum exists.
I want to perform a 2D analysis (GOM Correlate) with respect to a distance.
Also, the process is relatively fast, so I used a camera with around 240 fps.
So let's move on to my question, what are the requirements for the optical marker.
I have some available here that are even self-reflecting (perhaps not GOM) whereas there are often problems detecting them.
Thanks a lot!
Max
Hi Maximilian,
i suggest you are talking about the reference point markers.
You need nearly ideal round markers. With a white inside circle and a black one on the outside. We need a ideal circle for a better tracking of the coordinate because we going to fit a ellipse where the gray value gradient has the highest value. Approximately the middle point of the ellipse is the coordinate you are tracking.
The requirements of the markers are:
  • ideal 10 pixels of the white area (inner circle)
  • good contrast between white and black (if self created) - also influenced by the illumination
    • can be self-reflecting if you use tracking spots and measurement with a higher measurement frequency
  • other requirements based on the location you stick your points on.
    • minimum 3 better 5 for a point component
    • not on curved or high deformation areas
I hope this helps. If you have further questions, feel free to ask.
Greetings, Ivan
