[Ca...] Posted May 13, 2024 Share Posted May 13, 2024 I saved a project last week, and now when I've come back to continue on the project there is an error when importing: As the error suggests, I have tried to use the "Recover Project" tool, however this does not work either, instead coming up with this error message: Are there any other troubleshooting steps I can try to recover this project? A significant amount of work was put into this. I had thought that dragging a project into an existing file can sometimes bring up an option to insert a part into the open project. But that is not working in this case, possibly due to the file in question being a stage project? I am mainly after the mesh data for each stage. Link to comment https://qualityforum.zeiss.com/topic/3970-project-recovery/ Share on other sites More sharing options...
[Be...] Posted May 22, 2024 Share Posted May 22, 2024 Hi, in the case of concrete data problems I recommend the professional support of your local ZEISS partner. Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/3970-project-recovery/#findComment-11548 Share on other sites More sharing options...
[Du...] Posted June 11, 2024 Share Posted June 11, 2024 I've dealt with this issue in the past, unfortunately i was never able to recover said project. Now i have an unhealthy obsession with over saving and making back ups of all my projects. Link to comment https://qualityforum.zeiss.com/topic/3970-project-recovery/#findComment-11697 Share on other sites More sharing options...
[Ja...] Posted June 13, 2024 Share Posted June 13, 2024 Caleb , as bernd says , if you tried the tool and it doesnt give you what you want or doesnt work you can try to provide the project to the team where they can try with extended developer tools ..but this is not a guarentee that it works . As a guess as to maybe how you got in this position are you saving over a network? If so what software version are you using? Link to comment https://qualityforum.zeiss.com/topic/3970-project-recovery/#findComment-11743 Share on other sites More sharing options...
