Scanning with wireless remote control
Hi,
i have an ATOS Q and i have a problem with my wireless remote control.
Until verson 2020 it worked fine but since version 2021 to now with 2023 when I try to launch a normal Scan, with the right button of the remote control, it instead starts a Deformation analysis. How can i solve this?
We tried with both the provided controllers, the Logitech R400 and the Kensington Si600, they behave the same.
Thanks
  • 1 month later...
Hi,
could you check the preferences for the key bindings? Maybe there is also a remote key assigned to a shortcut under View -> Screen Setup -> Shortcuts.
Does the space bar work by the way for scanning?
Nanno
  • 2 weeks later...
There is no remote key assigned on any shortcut.
The spacebar and all the system works as usual.
I checked again now and i can confirm that is a version-related problem, because if I use it with version 2020 it works for scanning, but with 2023 it doesn't start the scanning
