Table editing
Hello
Whenever I try to modify the content of a cell in the table it always apply to the same scalar that was selected instead to the hole table.
Is there any way to make this changes to all of them at the same time?
For example here I changed the first column to white but it only affected the parallelism check instead to the hole row.
Has anyone incurred to this before?
Hello Alberto,
usually you don't want to treat angle checks the same as distances or GD&T checks for example. The color must be defined for every type seperatel.y. I will add this forum entry to an existing wish to change a column as a whole.
Nanno
Thank you for the feedback Nanno.
But what if I want to add something that can be added to all of them like a check of Ok and No ok.
Is there any way I can do to all of them?
Thanks
