MEASUREMENT POINTS OF STYLE
Hello Dridi,
the forum is meant to help each other in the community, so answers are slower than over the official gom support channel or your distributor.
You can construct the points via construct -> point -> surface point and then chose "edit point" in the dropdown. Here you can enter the coordinates of the points. Afterwards, it might be necessary to chose operations -> elements -> adapt element to CAD (position and normal). This is covered in our basic training by the way, so maybe you want to have a look at training.gom.com
Regards,
Nanno
Snag_1a5e81a3.png.fb18223d0b9c63f25294127cf19e9a30.pngSnag_1a5e9153.png.b2dba1a504bd5e3bfdaf55d6e7808008.png
Hi Dridi,
to me this does not look like a surface profile which is based on points. The drawing tells me that somebody is interested in the point deviation values for the values that are not inside a box. The surface profile is a completely different story. It is based on full surfaces and therefore patches have to be selected to inspect the profile.
Unfortunately the drawing excerpt is not really clear which surfaces to use. Maybe there is another view which clarifies it a bit more?
From my opinion the following things have to clarified first:
1) Which surfaces have to be used for the profile.?
2) If the requesting person really (where I'm not really sure about, because you loose information) wants to limit the surface profile to the points information, this is possible by using deviation pickers on the corresponding surface profile which are based on the point locations.
Hope this helps to get a bit further.
Best regards
Dinko
  • 4 years later...
Hi,
The point about measuring specific style points instead of relying only on a full surface profile is really helpful. Defining the correct reference geometry first can make the inspection results much more meaningful and easier to compare. I also like exploring for creative text styles when preparing clear measurement reports, labels, or presentation headings.
Use something like the splitline tool in solidworks to create defined target zones, perhaps like .5mm, 1mmn, or 2mm in diameter.  You can defined the coordinates where you want.  Then use those zones to create a patch surface and use that surface for profile.
I've used and liked this approach - since i have a nominal points, then just create a point cloud from point's actuals and instead of data from mesh you select this point cloud.
