Plane normal on touching surface
Hi,
I have a question to experts to make to following:
I have a injection molded valve seat with cyllindrical surface.
I need to know the surface normal of the fitting plane. ( ...evaluate the direction of warpage )  What I did up to now:
- selected the surface from cad patches
-created a nominal plane with chebisev/ outer fit.
- I have selected the measurement principle as fitting element.
My questions are:
- Is my method is good to do what I trying to achieve?
- How I can get the direction (normal vector) of the measured plane?
Thank you in advance.
Ferenc
I would recommend using Gaussian best-fit (outer), since it is less sensitive on the extend of the actual selection than Chebyshev. The normal of the plane is available in any command that uses a direction by selecting it in the respective widget. For scripting (or user defined checks), the normal can be accessed via gom.app.project.actual_elements['LavalEdgePlane'].normal.
