export table contents
Hi Everyone,
What is the best way these days to export .csv inspection results from GOM Inspect Pro?  Years ago I downloaded a python script from the support site here that exported one .csv file of the table for each stage.  We would customize the table to match the format of our other inspection software, and the exported .csv files would integrate into our existing semi-automated reporting process.  What happened to that script?  I think it was called export_table_contents, and it was part of a nice scripting tutorial.
Edited
  • 2 weeks later...
Dear Aaron Everman,
I don't know the script you mentioned but you could try the attached script which I made really quick. It asks for a folder and then exports all data into a csv file, using the current active table format, for each stage.
Does this help? You can always adapt the script for your needs.
Best regards,
Daniel Schrein
csv_export_all_stages.py
  • 2 weeks later...
Thanks Daniel, I'll check out your script.  It seems like a lot of helpful old reference information has disappeared from this support site.
