Software crash when loading
Hi,
Since upgrading from Inspect 2022 to 2023 I can no longer load the program. At 55% loading it always crashes. I've been back and forth with support sending dump files, deleting config files, etc. (ticket CNR-184070-X4D5Q1) but it's still not working. Has anyone had this happen?
https://qualityforum.zeiss.com/topic/4290-software-crash-when-loading/
Hi Alexander,
Have you verified that Inspect 2022 still functions? I have had this issue a few times in the past and usually a fresh install of Inspect would fix it. There were a few times where I had to completely clean out the ZQS as well and start from scratch.
If you're already in touch with your distributor then it will eventually get sorted out.
  • 2 weeks later...
