Remove connector label
Hi,
it's not possible to remove the connector line from your label, you can only hide your label. Editing the connector point should work with the (professional) version. If it's not working you have to contact your local ZEISS support for a deeper investigation of your particular project.
Regards
https://qualityforum.zeiss.com/topic/4382-remove-connector-label/#findComment-12982
