New to cmm
3lines.thumb.PNG.8902ca5dad2c09793bb11d73c1058ee8.PNGintersection.thumb.PNG.76b6a3f6ffe33117930dbd054eada9c1.PNGalignment.thumb.PNG.802e012569ebdff2c616b493e2941104.PNGcaliperdistancewithalignment.thumb.jpg.52976550ff38ca80f648825bcf9347a4.jpg
This is what I am thinking. Create 3 lines, single points are fine. Then, create an intersection point from the two lines to the left. Create a utility alignment, open it and place the largest line as your planar rotation (keep in mind, probing direction dictates whether it will be plus or minus axis). Leave everything else blank in this utility alignment. Create a caliper distance, going from the intersection to either the center of the clocking line, or create another single point along the line. Make sure in the caliper distance that the new rotated alignment is active. Then select the distance in the respective axis. This should get you in the game. Best of luck.
