Using Caliper Distance, odd result.
I have to intersection points that are in a Caliper Distance and using an alignment that is aligned to the feature (Hole in the part).
(Ignore that I am using 8 decimal places).
ZY -6.54839145°
XY -7.00000000°
I know my alignment is correct, based on finding location at its nominal Zero per axis from the model.
When I create the characteristic, it appears odd.
See attached image.
Why is the angled measure line stopping short of where it should be?
The nominal should be (SB) 2.475.
These are definitely intersections, they show an cross hair for each, no lines protruding from either one.
Not sure why but creating Points from the Intersections solved this issue.
Thanks for the tip. 🙂
