Turn off preview Mesh
         Is it possible to set a button to turn off preview Mesh in the software? Because after SW2019, we have felt that software scanning has become more and more time-consuming. Now I can only display the measurement sequence when scanning, and turn off the update button, which can be solved temporarily. In this way, the software will not calculate the preview Mesh temporarily. However, it is still very time consuming to calculate the preview Mesh after the public reference point is converted in the acquisition of the new measurement sequence later. Customer feedback is not good, and they feel that this is too much trouble and affects efficiency. The demonstration engineer thinks it will affect the demonstration effect and efficiency. Will not help us to promote the software.
         Please help find a suitable solution.
         Thanks for help
Asia.china.(Ren yongfei)
https://qualityforum.zeiss.com/topic/478-turn-off-preview-mesh/
Hello,
the preview mesh will not be calculated when the autocalc button is off and the preview mesh and every dependent element (like fitting elements on the mesh) are also invisible.
In the gom software 2021 the autocalc button will also disable the preview calculation when transforming measurement series via common reference points.
Regards,
Nanno
https://qualityforum.zeiss.com/topic/478-turn-off-preview-mesh/#findComment-1443
  • 3 weeks later...
