Is it possible to offset measured points
Martin Jánský, I think making a new offset alignment and using it to evaluate the profile will do nothing because like you said the measured points are fixed to the CAD.
In the freeform surface, activate a best fit alignment. Activate which degrees of freedom you want to allow. The new best alignment will report how much movement takes place to get to the best fit.
  • Create a new point
  • Select "Recall One Feature"
  • Right click on nominal you wish to modify output of
  • Select Formula
  • Add value to "getActual(featureName).instanceVariable"
Your shifted point is now represented by this theoretical point feature
