SSC-How to get more Renishaw style probes?
Is there a way to get more M2 and M3 probes listed in Stylus System Creator?
Like Renishaw probes and extensions.
We have many probes using M2 or M3 extensions and probes on XT and XXT sensors. We need the slim body diameters.
I am trying to create probes in S.S.C. for offline work and there just aren't enough choices.
It's been years since I built any Renishaw probes because we no longer use them, but I remember using the generic options for extensions and probes. You can customize any diameter and length.
You can import additional stylus files and databases into SSC aside from what exists by default. Here is a ZEISS KBA that explains this in more detail: https://portal.zeiss.com/knowledge-base?id=851021
In the article it mentions getting additional SSC files from ZEISS but in your case it sounds like you may need to ask Renishaw for theirs? Maybe they have a package they could send you for import, might be worth asking them at the very least.
