[Ri...] Posted August 8, 2024 Share Posted August 8, 2024 I seem to be struggling importing an SSC file and having it "Update" the current probe with the same name. After updating and viewing the probe in "Stylus system management", the list is still the same. When trying to assign a stylus tip (from the list) the available tips are only what was created in Stylus System Creator. How do I associate the stylus tips from the original probe to the SSC probe? I don't think I have ever tried to do this. Edit: The list eventually changes to the SSC file probes, and my original list disappears. Link to comment Share on other sites More sharing options...
[Cr...] Posted August 9, 2024 Share Posted August 9, 2024 Make sure your SSC and PCF file names are exactly the same. Did you click the "Creates a new stylus system" button and then click update? Screenshot 2024-08-09 052158.pngFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted August 9, 2024 Author Share Posted August 9, 2024 Using "Update" does not work. I imported an SSC file. Link to comment Share on other sites More sharing options...
[Cr...] Posted August 9, 2024 Share Posted August 9, 2024 It's been a while since I've done this. I don't think the PCF file will work. You will have to use a Text file. If you have the stylus on another machine, go to Rotate stylus to new position- Styli List- Save. This will be the text file you load after you've imported the SCC file. Link to comment Share on other sites More sharing options...
[Je...] Posted August 9, 2024 Share Posted August 9, 2024 There are very few instances where a PCF and an SSC should cross paths. PCF = CNC use (location from Actuals). SSC = Planner use (location from nominals). They are not simple to make co-exist and a standard "Update" when importing the SSC will not function. You can maintain your RC list by exporting the RC list prior to SSC import. https://portal.zeiss.com/knowledge-base?id=528291 Link to comment Share on other sites More sharing options...
[To...] Posted August 9, 2024 Share Posted August 9, 2024 Please sign in to view this quote. Not sure if this will help you. Stylus System Transfer (1).pdfFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted August 12, 2024 Author Share Posted August 12, 2024 Please sign in to view this quote. This doesn't seem to work on XT or XTR sensors, unfortunately. Thanks for the help. Link to comment Share on other sites More sharing options...
